Group: DynoMotion Message: 7114 From: daves3891 Date: 3/25/2013
Subject: Motion Clamps (Again)
I had discussed how to add motion clamps on CNCzone and I had a few more questions and I decided to move the topic here.
I have modified the interpreter to let me use M15 and M16 with the call backs so that part is done.
Now I want to use a C program to do the following for the motion clamp cycle.
Here is a basic program flow
- Check for the motion clamp bit (set by M15)
- Monitor for the X and Y axis to both stop
- Pause or stop the interpreter/buffer
- Activate the Motion clamp output
- Wait for 1 second
- Start the interpreter
- Wait for the Z axis to return to the start position
- De activate the Motion clamp output
- Wait for 1 second
Does this sound feasible with a C program?
What is the bast way to monitor if the axis has stopped moving and pause the interpreter?
Any suggestions would be appreciated.
Dave
Group: DynoMotion Message: 7116 From: Tom Kerekes Date: 3/25/2013
Subject: Re: Motion Clamps (Again)
Hi Dave,
I don't really understand what you did with the M15 and M16 or why you needed to modify the Interpreter source code to make an M Code just set a bit.
An M Code will naturally wait for any previous motion to stop before executing.  And the Interpreter can be set to wait for an M Code to finish before going on.  So there isn't really any need to start/stop the Interpreter.
From the earlier thread I thought you wanted to use the canned drill cycle with dummy Z motion?
Group: DynoMotion Message: 7119 From: daves3891 Date: 3/26/2013
I modified the interpreter because it was giving me a unsupported M code error when I was using M15, I just modified the _ems[] in the rs274ngc file to use group 10 instead of -1. I think this was the correct way to do it but I am not 100% sure.
I do not need a dummy canned cycle, I need the standard drill cycle but have it activate the clamps before the Z starts moving and deactivate when it is retracted (only is M15 has been set in the beginning of the G code)
The motion clamps will only be used with canned drilling cycles
We have this feature on one machine that is a custom DOS based software with a galil board and a second newer machine that has a Fanuc controller and does the motion clamps with the built in ladder logic. I would like to get this working on our third machine with the kflop and if it is successful and reliable use the same system to replace the galil system.
I need the system to be accurate as some of the work pieces we drill are $20k+ for just the material.
I looked at adding something in to the interpreter code itself, but I really do not fully understand how I could get a message from the rs274ngc to the kflop. I am confused about the flow from the interpreter messages to the board.
That is why I was thinking the C program monitoring the z position might work well, but I am still open to suggestions on the best way to accomplish this.
Dave
> Hi Dave,
> From: daves3891 <fahque99@...>
> Sent: Monday, March 25, 2013 1:02 PM
> Subject: [DynoMotion] Motion Clamps (Again)
> - Wait for 1 second
> - Wait for 1 second
> Thanks
> Dave
Group: DynoMotion Message: 7120 From: Michael Rosenfield Date: 3/26/2013
Another approach would be to modify your post-processor - asuming you are using CAM software - to handle the clamps. That is what I did for my mill - a Tree machine with a manual quill to which I added a servo drive. There was too much slop in the quill rack to hold position, so I clamp after it reaches Z position, before any X-Y moves, and  unclamp it before a Z move, after the X-Y move is complete.
I'm using Bobcad, by the way - an inexpensive product that I can highly recommend.
Michael Rosenfield
Group: DynoMotion Message: 7121 From: daves3891 Date: 3/26/2013
I want to stay away from doing it with G code, we try to keep the code consistent between machines and it would be more difficult for the operator to restart a program from different hole locations.
Thanks for the suggestion
Dave
--- In DynoMotion@yahoogroups.com, Michael Rosenfield <mrosenfield@...> wrote:
> Another approach would be to modify your post-processor - asuming you are using CAM software - to handle the clamps. That is what I did for my mill - a Tree machine with a manual quill to which I added a servo drive. There was too much slop in the quill rack to hold position, so I clamp after it reaches Z position, before any X-Y moves, and unclamp it before a Z move, after the X-Y move is complete.I'm using Bobcad, by the way - an inexpensive product that I can highly recommend. Michael Rosenfield
> From: fahque99@...
> Date: Tue, 26 Mar 2013 14:20:05 +0000
> Subject: [DynoMotion] Re: Motion Clamps (Again)
> Hi Tom,
> Thanks
> Dave
> > Hi Dave,
> > From: daves3891 <fahque99@>
> > Â
> > - Wait for 1 second
> > - Wait for 1 second
> > Thanks
> > Dave
Group: DynoMotion Message: 7122 From: Tom Kerekes Date: 3/26/2013
Hi Dave,
I think there is a few more things to do to add additional M Codes.   That change just tells the GCode Parser that it is ok for the MCode to be in the GCode, but additional code would be required to actually make it do something.  As well as GUI changes to allow the GCode to be configured by the User.
I'm thinking that the best approach since you must conform to existing GCode and are able to modify the Interpreter would be to modify the Canned Drill Cycle to add the additional Clamp functionality.  I think this would be relatively straightforward with several MCode Calls added.
I suggest using a Subroutine first to prove the concept.  Once it is working you can modify the Interpreter's Drill Cycle to do the same thing.
The Subroutine would consist of:
#1 Move XY using G0
#2 M100 - call c program to wait until in position and clamp (abort on timeout)
#3 Drill Z using G1
#4 Retract Z
#5 M101 - unclamp
Does this sound reasonable?
Group: DynoMotion Message: 7123 From: daves3891 Date: 3/26/2013
That sounds exactly like what I need.
I did change a few other things to the interpreter code, I also made MAX_MCODE_ACTIONS_M1 21 instead of 11. This has allowed me to get a valid call back from the GUI.
But if I am modifying the interpreter then I guess I don't need to worry about the GUI callback as much.
I might also need to add a delay after the M100 / M101 (clamp unclamp)
Would I basically just be able to add the correct messages to the rs274ngc (eg, set a M code)?
Dave
> Hi Dave,
> #1 Move XY using G0
> #3 Drill Z using G1
> #4 Retract Z
> #5 M101 - unclamp
> Sent: Tuesday, March 26, 2013 7:20 AM
> Hi Tom,
> Thanks
> Dave
> > Hi Dave,
> > - Wait for 1 second
> > - Wait for 1 second
> > Thanks
> > Dave
Group: DynoMotion Message: 7126 From: Tom Kerekes Date: 3/27/2013
Hi Dave,
Not sure what you mean by adding messages.  But you should be able to do everything using a subroutine without changing anything in the Interpreter.
Then later if you modify the Canned Cycle to include M Codes you can use existing M Codes (Since they will be hidden from the Operator it shouldn't matter which ones they are).
If an M Code calls a C Program you can easily add any required delay in the C Program.
Group: DynoMotion Message: 7127 From: daves3891 Date: 3/27/2013
Well I have it working with a code change to the interpreter.
It was pretty simple once I figured out what I needed to do
I went to the convert_cycle_g81 function in the rs274ncg.c and added
M100(100);
DWELL(1);
before and after the (the after is M101 to turn off the clamps)
cycle_feed(plane, x, y, bottom_z);
cycle_traverse(plane, x, y, clear_z);
So now I will just have a functions that will enable the clamps if both M100 and M15 are on
And set M101 to always turn off the clamps whether or not M15 is active for safety
Dave
If you see any issues with this please let me know.
> Hi Dave,
> Sent: Tuesday, March 26, 2013 11:09 AM
> Thanks
> Dave
> > Hi Dave,
> > #1 Move XY using G0
> > #3 Drill Z using G1
> > #4 Retract Z
> > #5 M101 - unclamp
> > Hi Tom,
> > Thanks
> > Dave
> > > Hi Dave,
> > > Regards
> > > - Wait for 1 second
> > > - Wait for 1 second
> > > Thanks
> > > Dave
